2000 D2 SAI possible issues
Old Oct 25, 2018 | 12:49 PM
oaty's Avatar
Default 2000 D2 SAI possible issues
What are some issues the rear its head when the Secondary Air Injection has problems? Does engine go under powered. My engine has been under powered since I purchased 2017.
Old Oct 25, 2018 | 03:01 PM
Best4x4's Avatar
Emission faults, 1412,1415, loud jet sound at startup, no sound at startup, and a vacuum leak is about all the SAI will do. Shouldn’t rob any power, clogged cats, weak fuel PSI, clogged injectors, dirty air filter, slack in throttle cable = no power.
Old Oct 26, 2018 | 07:32 AM
oaty's Avatar
Sorry for the horrible typing. Was in a hurry. Just trying to chase down why my D2 shudders when accelerating. Not always, but usually. Runs fine on the interstate, but at take off, sometimes feels under powered and shudders while accelerating. Usually shift down into 3rd to help. Hills are also a struggle sometimes.
Old Oct 26, 2018 | 08:29 AM
2Guinness's Avatar
Default Jet
I get the loud Jet sound at startup, I thought it was normal... Is there an issue to address?
Old Oct 26, 2018 | 08:36 AM
Best4x4's Avatar
Yes the Jet sound is normal at startup however if you have a CEL on it could be due to the main line from the pump has fallen off, or it’s broken = system will be INOP and it will be slightly louder than normal.
eagleconrado
Dec 16, 2020 01:53 PM
pvenuti
Nov 11, 2014 08:10 AM
dparham
Aug 21, 2014 10:13 AM
tparsons
Jul 28, 2014 12:53 PM
neroverguy
Mar 3, 2010 07:19 PM
