2000 Dics codes P0446 and 1174
P1174 -
P0446 CVS valve / pipe blocked
Your CVS is blocked. Don't believe you can clean this, but might try some sort of injector cleaner added to gas.
Page from RAVE. By the way, if you have the RAVE, you can use your search feature to go right to any code number.
Additive injector adaptive fuelling - lean limit exceeded
RH bankP0446 CVS valve / pipe blocked
Halftrack99
07-25-2015 10:52 AM
