2000 Dics codes P0446 and 1174
Old Dec 2, 2011 | 11:44 AM
Mclaint's Avatar
6th Gear
Exclamation 2000 Dics codes P0446 and 1174
I have a 2000 Disc 2 with 189,000 miles new O2 sensors. But I知 now I'm still getting two codes P0446, 1174 does anyone have a clue where I should start .
I put in new plug wires and plugs,Gas Cap and coil pack. And I only use 93 octane gas
Old Dec 2, 2011 | 12:45 PM
P1174 -
Additive injector adaptive fuelling - lean limit exceeded
RH bank
P0446 CVS valve / pipe blocked
Your CVS is blocked. Don't believe you can clean this, but might try some sort of injector cleaner added to gas.
Page from RAVE. By the way, if you have the RAVE, you can use your search feature to go right to any code number.
File Type: pdf
Halftrack99
Jul 25, 2015 10:52 AM
Mclaint
Jul 28, 2011 04:17 PM
BIG g
Jul 26, 2010 04:43 PM
DEEBEE060
Aug 19, 2009 04:39 PM
dewhorse
Oct 29, 2008 01:00 PM
