2000 DII Brake Job
Old Jun 24, 2006 | 05:21 PM
Default RE: 2000 DII Brake Job
Remember to let the brakes break in slowly, no panic stops for a couple of days.
Mike
Old Apr 21, 2012 | 03:03 PM
RedAustinIX's Avatar
Just finished doing my front brakes/rotors. I used OEM Land Rover rotors and pads. My question has to do with the first couple of stops after everything is installed. The rotors/pads made a horrible grinding noise and was very slow to stop. After doing controlled stop about 5-6 times, it got much better. I'm assuming this is because the pads were wearing off the black coating on the rotor? Is this the right way to do it, or should I have used sandpaper, a wire brush or something to prep the rotor first? I did spray the rotors with brake cleaner before installing, but that didn't appear to help.
Thanks!
RedAustinIX (Ed)
Old Apr 21, 2012 | 06:42 PM
Discovery SE7's Avatar
A lot of the rotors have a coating over them to help prevent rust and corrosion while they sit on the shelf. It is better to clean them before putting them on the vehicle, but I think most people just let the pads wear it down. If you do clean them, you can use break cleaner to get the oil off.
a-rod
Sep 21, 2013 09:33 PM
Antmen
Jul 4, 2013 05:01 PM
Danny Lee 97 Disco
Aug 14, 2010 08:03 PM
kemil77
Jun 22, 2010 10:53 AM
surf9ska
Feb 14, 2006 03:52 PM
