2000 Disco heated windscreen connector melted
Old Feb 18, 2015 | 05:54 PM
thegails's Avatar
Default 2000 Disco heated windscreen connector melted
Hey guys, my disco heated windscreen stopped working on the driver side. Not sure when, sorry. It did work at one time. I checked the 40A fuses, ok. I checked the connectors under the cabin filter, passenger was fine. Driver side connector was melted around the contacts, once I managed to get the halves apart. Not sure how this got so hot and did not blow a fuse... Isn't that the idea? Anyone have any thoughts on this? There are no cracks or chips in the windscreen. I will check the resistance and voltage tonight, to make sure everything (except fired connector) is as it should be. I guess I could make a jumper to go from the passenger side, just to make sure the driver side is not defective. Thanks for your help!!!
OilPatch
Feb 15, 2015 11:14 AM
cgap
Dec 4, 2011 12:18 PM
mcwilly21
Jan 30, 2011 09:36 PM
mutley-uk
Oct 22, 2010 02:14 PM
skswindon
Dec 16, 2006 12:15 PM
