2000 Disco II Heated Seats
Old Apr 20, 2014 | 10:26 PM
DiscoZen's Avatar
4wd High
Default 2000 Disco II Heated Seats
Hey all,
Just recently acquired a 2000 Disco II w/143k miles. Head gaskets etc all done - no over heating issues... seems to be a good truck.
Most of the issues are cosmetic or enhancements...
I read in some forum - this or another - where it seemed like if I can find a fascia panel with the buttons for heated seats, my leather seats may already have the wiring in them and it is just a question of hooking everything up. Is that correct?
Thanks,
-Stu
Old Apr 20, 2014 | 10:33 PM
ralphobell's Avatar
Yes sir! I did it to my truck. If you have the leather seats then all you need is this:
Land Rover Discovery 2 Window Switch Panel w Heated Seat Switches 99 02 03 04 | eBay
Old Apr 20, 2014 | 10:51 PM
DiscoZen's Avatar
4wd High
Thanks -
I ordered the panel and it's on its way. I'll probably resurface when I get it, just to ask for any "gotcha's" when wiring the seats up.
Winter is FINALLY almost over - but it'll be back and nice to have the warmers.
Thanks again...
Old Apr 20, 2014 | 10:54 PM
ralphobell's Avatar
No real gotcha's. Remove the panel, fasten connectors, attach panel. Plugs will only fit the switch they are designed for. Only real issue I think you could get the left and right seat warmers mixed up. But easy enough fix if you do.
Old Apr 21, 2014 | 09:22 AM
SuperSport's Avatar
Here is all you need:
Old Apr 27, 2014 | 08:02 PM
DiscoZen's Avatar
4wd High
Default Bun Warmers Operational
Thanks to everyone and especially ralphobell.
Purchased the facia panel, swapped out panel and plugged in the connectors - I even got Left to Left on the first try and they work fine.
I will need to fab up a piece of aluminum to create lower screw holes, but you can't tell anything wrong with the cover panel on.
Thanks again,
-Stu
Old Apr 27, 2014 | 08:39 PM
ralphobell's Avatar
Your very welcome!
Yeah, I fabed something similar until I found a pristine center console at the bone yard. I wish someone had not beat me to the front seats. The inside of this thing was immaculate.
bballjames
Jul 16, 2012 02:51 PM
Savannah Buzz
Feb 15, 2011 05:48 PM
booper169
Nov 9, 2010 09:10 AM
Fonzie
Jan 7, 2008 07:51 PM
