2000 Disco II Major Rebuild/Overhaul
Old Aug 2, 2014 | 10:31 AM
  #61
RSPTex's Avatar
I just bought the plugs that are the same part number from Britpart. I bought most of my parts from lrdirect, getting Britpart Brand stuff. It is much cheaper than elsewhere. I like the quality of what I've seen so far. great stuff. The plugs look like a coated aluminum. I'll give them to the shop and have him do them. I'll pressure test after doing everything else and see what I turn up with. I put a good deal of pressure on the threading to make sure I didn't pull it out while cutting, and when pushing on the Cast Iron, perhaps it did deform. I'm still optimistic that it's just my eyes playing tricks on me. I'll know on Monday, though.
Originally Posted by RicketyTick
Wow! I would have guessed that they may flake a little but had no idea it would take enough pressure on the sleeves while cutting to warp them...especially with new drill bits and cutting fluid. probably not ...or hopefully not.
Looks like your freeze plugs are about done, I guess your machinist will be putting in new ones. Wonder if he will be using brass replacements? ask him if he pulls those out to the outside or knocks them in and then bends them and gets them out. . I've read that it's easy to gouge the aluminum pulling the freeze plugs out to the outside and may cause a leak later. I've also read that you can pull them to the outside with a dent puller and no problems? I'm curious as to how a machine shop goes about doing that on an aluminum block.
I noticed your block looks clean in the pictures with the drilled holes. did you have it cleaned at a machine shop once already? I was also wondering if you got around to having it pressure tested?
A few more questions...what brand of lower end bearings and rings did you buy? curious if some are really better than others? like federal mogul or AE or Glyco main and rod bearings being better than some of the really cheap ones.
I know the genuine bearings are 3 times the price of federal mogul, AE, Glyco. There may be other brands that are most popular across the pond? wondering what your research has turned up on all of that and what you decided to go with?
Old Aug 2, 2014 | 11:47 AM
  #62
dr. mordo's Avatar
Great thread!
Originally Posted by RSPTex
-How does anyone get to the centering ball kit on the read diff to replace it? (as directed in Disco Mike's Major service)
The only centering ball I'm familiar with is in the D2's front driveshaft. This thread has pictures and a description. I seem to remember the D1 shaft lacks the double cardan joint, and so doesn't have the centering ball.
Which is a good thing IMO. This thread makes me wonder if it's possible to swap the flanges and use a D1 driveshaft.
Old Aug 6, 2014 | 05:34 PM
  #63
RicketyTick's Avatar
Hey Tex, how's it going?
Old Aug 7, 2014 | 02:18 PM
  #64
RSPTex's Avatar
Default Rebuild Update!
This is a great project! I've pinned the sleeves, and they are now being honed and the block is also being decked, having new cam bearings and freeze plugs put in. I found that on one half of my block the screw depth was .050" longer than the other side, with variation between the 4 cylinders of each side being less than .010". You'll notice on the diagram of depths, the screw length is 1.045" and the depth I measured was the surface of the block to the top of the screw with a depth gauge. I was able to then use nuts to lock in place where I wanted to cut with a dremel and sand/finish the screw from there. I heavily advise against pinning sleeves while the engine is assembled and in the bay. There's particulate matter that WILL fall on your crank, journals, connecting rods, and WILL be picked up by your oils feed pipe and be put into your oil pump, lifters, rockers, etc! I don't think there was any warping done to the cylinders. Some 1200 grit sandpaper and oil was able to get rid of almost all of the lip that drilling and tapping made. The honing of the cylinders is going to take care of the rest.
I have the exhaust manifolds back from being sandblasted. They aren't red with rust anymore! I need to put new studs in them, though. 3 broke, and the other 3 can't be far behind. The pictures are of the manifolds in my motorcycle saddlebags. Sorry for the weird angle.
[IMG] https://googledrive.com/host/0BzP5dF...0/IMG_1663.JPG[IMG]
I'm still waiting on the valves, and then I can finish the heads after lapping the valves to their seats.
I've installed the front axle's lift, which looks really goofy, given it has nothing to weigh it down, so it's super tall. I bought the TF 2" lift kit, and the truck was already using 1" spacers up front, probably to offset the weight of the ARB Bumper. I ordered some aluminum to machine a pair of spacers for the back and give the truck an even 3" lift.
While doing the suspension, I also tried to replace all the brake stuff. That was a crazy experience. The first one is always the worst. It took 4 hours! The brake lines sent didn't have the right fittings and only grabbed onto about 2 threads of the male thread from the truck. Very bad! I'm having new lines sent, which will get here first part of next week, which is also when I'll put the rest of the suspension on. I also have new raybestos rotors and power stop ceramic pads. When I replace the brake fluid, I'll also install the speed bleeders to make that go faster. I've used them on my motorcycles, and you can't beat them! It turns a 30 minute job into a 5 minute job with no stress and very little waste.
I haven't done anything with the transmission or transfer case, yet. I need to read up on rebuilding the transmission so I can get that done and then install new gaskets and seals on the transfer case. Rusty1 was awesome enough to send me an old double cardan front drive shaft that I'll rebuild and put on the front, using the flange that mates with the transfer case (mine uses a D1 flange...). I'm debating the rear driveshaft. I could get another rotoflex, but with 3 inches of lift, I am considering just doing a double cardan on the back, as well. I just don't know how to do it, yet...
Because the truck is gutted, I am now looking at doing the headlight conversion. When I bought the 03-04 headlights to put on my 2000, they were both oxidized, but came with the pigtails of the connectors from the truck, which makes splicing those wires with my truck's very easy. I'll take a grinder to it this week or weekend and get those fitted...then removed to prevent damage while doing everything else. I am also repainting the wheel flares and grille. Paint and sandpaper are cheap, and I am still waiting on parts, so I have time.
I've organized all of the work I'm doing into folders in my google drive. They're continually changing, but here's the link to the folder, so anyone can enjoy access to all my write-ups, photos, specs, notes, etc:
Robbie's Disco II Google Drive Folder
Anyone can view and download everything in it, but you can't modify the them on the google drive folder. You can download all of it and modify it for your own use, though! I'll be updating all of the projects as they get closer to being finished. As you'll see, some of the projects are empty because I haven't started them, yet. They handsfree entry/keyless ignition is still being developed. It'll be awesome, though, I promise you that!
I've also been working on cataloging the specs to all of the bolts I need to replace and get high-end replacements. The spreadsheet for that is in there. I'm only about 1/4 the way through what I want to do on the fasteners.
Screw Land Rover (get the pun?!)
That's all I have for now. I'll let you all low more when I do more. Turns out my wife wants to do things that don't involve a wrench some nights, so I don't get to work as much as I'd like to....
Old Aug 7, 2014 | 04:41 PM
  #65
acamato's Avatar
Did you get seats cut?
Old Aug 7, 2014 | 08:05 PM
  #66
Great update! You two are really getting alot done. I wish I were half as productive.
I don't know how you do it...with school, job, and building a truck!
3" lift...nice job...you may need a pair of drywall stilts to work on the engine!
Tough truck!
Thanks for access to your notes!
Old Aug 8, 2014 | 04:18 AM
  #67
RSPTex's Avatar
Not cut, but they're in surprisingly good condition, so they shouldn't need to be cut. We'll see how lapping goes, though. Maybe they will need to be recut.
Old Aug 8, 2014 | 05:22 AM
  #68
acamato's Avatar
After you lap them. Test them to make sure they seal. On the bench with the valves installed fill the combustion chamber with water and see if they hold the water.
It would suck, to spend all this time and money to have valves that leak.
Old Aug 8, 2014 | 06:16 AM
  #69
drowssap's Avatar
you should just have the valves and seats cut and be done with the heads. also as long as you had the manifolds blasted have you consider coating the insides to hold the heat IN.
Old Aug 9, 2014 | 12:09 PM
  #70
RSPTex's Avatar
Yeah, just talked to my machinist yesterday and he's going to do it for free since I've had him do so much other stuff. Then I'll lap them. Good call.
As for coating the inside liner of the exhaust manifolds, I am tempted to do it. The big question, is how much would it cost? I'm going pretty crazy on this rebuild, but I can only go "college-student-with-decent-income-and-more-tuition-due-in-September Crazy". If this is something I can do on my own, then I'll look into it, but if not... guessing it's not cheap. And why would you want to line the manifolds to keep in the heat? Wouldn't you want to coat the outside so the heat gets to the manifolds, but not to other things? The heat has to go somewhere, so if it's not radiating out of the manifolds, it's placing more heat load on the catalytic converters (and radiating to the front driveshaft U-Joints), or making the heads and block hotter.
When I reason it out, lining them sounds like a bad idea. Convince me, though. I'd like to know more about the concept and where else it's done, and for what reasons, with which successes.
Thanks!
I don't know how much work I can update everyone on this weekend. I sprained my ankle and got hit in the neck with a softball while sliding into third this Thursday. I'm pretty useless right now, so I don't know how much work my wife will let me do. On the upside, I finally get time to work on my media/security camera server. Not related to rovers at all, but I am proud of it:
- 3x SSDs in RAID 0 to run Mac OS
- 1x SSD to run Windows
- 8x 3TB drives in RAID 6 (can lose any two drives and lose no information)
- Liquid-cooled, over-clocked quad-core processor
- 1000W 80plus gold PSU
- GTX 760 Graphics card
- Custom case with remote-controlled red LED's (helps performance soooo much!)
It's a fast and powerful little beast. I named him Titan:
With Google Fiber, I have quite the little server!
That's all of my off-rover talk. Just happy to have time to work on it!
