2000 Disco II Rough Idle, Radio issues
Old Jun 10, 2016 | 02:41 AM
samroy92's Avatar
Default 2000 Disco II Rough Idle, Radio issues
I posted this over in General Tech help as well, hoping to get all the advice I can.
This Disco has been running rough and threw misfire on Cylinder #5 code. If the car is idling in park and I press the gas pedal it has a faint shuddering. Once it stops accelerating and reaches a constant RPM the shuddering stops. When the car is moving and the engine is under load this becomes more apparent.
I decided to take a look under the hood and make sure the plug was still decent on Cyl #5, after tinkering around with the wire I noticed this radio issue:
So I replaced all the plugs and wires with Bosch +4's, and Magnecor 8mm wires from RoverParts. WHAT A PAIN IN THE ***. Still the same issue however, rough idle, rough acceleration, and now radio is going crazy. Now I get the occasional Cyl #7 code being thrown as well. I also will note that the #5 cylinder wire looked fairly corroded on the coil pack side - compared to the other wires.
Here are the current diagnostic codes it's throwing:
Old Jun 10, 2016 | 07:17 AM
NickAdams's Avatar
I did not watch the videos, but I'm guessing the coil pack is throwing spark at the radio. Did you double check the wire connections at the coil?
oilspotLR
Sep 25, 2022 08:14 AM
dogstarsix75
Apr 24, 2020 01:33 PM
dillhole
Feb 20, 2020 02:30 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
oljohnboy
Mar 20, 2009 09:44 PM
