2000 DiscoII engine hard to start
Old Jul 14, 2012 | 02:22 PM
928paul's Avatar
Default 2000 DiscoII engine hard to start
I have a 2000 Discovery II around 170K I have replaced water pump, radiator, thermal-stat, front crank seal, power steering pump, etc.
Recently had a engine check light on, I run OBD2 scanner and found out problem should be related to the fuel cap is leak so I replaced fuel cap and everything works find until 2 weeks ago when engine is cold very hard to start.
I found oil leaking from around starter area, does starter also lube by engine oil? O-ring or gasket is bad?
Thanks a lot for your help!
Old Jul 14, 2012 | 02:27 PM
No it does not lube by engine oil. If turning over, but no start, might check for spark (no spark will point toward CKP - crank shaft position sensor).
Old Jul 14, 2012 | 07:01 PM
928paul's Avatar
Default oil leaking from around starter
oil is leaking out from around where starter is located, and starter is close to the transmission but I can't get a clear look until I can put lift the car, what could be the problem causing oil leak? thanks
Old Jul 14, 2012 | 09:57 PM
Leaking oil pan gasket.
Leaking valve cover gaskets.
Neither of those will cause a hard start when cold.
Define hard to start.
snads
Dec 6, 2014 02:42 PM
RoverZebra
Dec 8, 2012 04:27 PM
mac25dm
Aug 2, 2007 09:17 PM
mach5288
Apr 26, 2007 09:22 PM
davidc99
Jun 1, 2005 04:05 PM
