2000 Discovery Heater Not Working.. Help!!!!
Yep disconnect the two hoses (I honestly cut them off to avoid hurting the solid heater core lines). You can just get 5/8 heater hose & cut it to length vs using the OEM $$ hose. Then flush it backwards first with a hose, then when it flows good and clean flush the opposite direction. In/out hose direction doesn’t matter as it’s just a loop.
