2000 Discovery Heater Not Working.. Help!!!!
Old Apr 2, 2019 | 04:55 PM
Brandon318's Avatar
Originally Posted by Best4x4
Flush just the heater core.
Simple as disconnecting the two hoses and hooking up a low pressure water source to the passenger/inlet port?
Old Apr 2, 2019 | 04:56 PM
Brandon318's Avatar
Originally Posted by JUKE179r
Flush and then backflush the heater core.
Oh, is backflushing accomplished by connection a low pressure water source to the driver/outlet side?
Old Apr 2, 2019 | 06:12 PM
Best4x4's Avatar
Yep disconnect the two hoses (I honestly cut them off to avoid hurting the solid heater core lines). You can just get 5/8 heater hose & cut it to length vs using the OEM $$ hose. Then flush it backwards first with a hose, then when it flows good and clean flush the opposite direction. In/out hose direction doesn’t matter as it’s just a loop.
jmason
Nov 17, 2013 06:39 AM
skatelove303
Jan 11, 2011 01:24 PM
TheRedRockDisco
May 23, 2010 09:34 AM
IDAHODISCO
Mar 6, 2009 01:16 AM
elrey10
Oct 9, 2006 09:23 PM
