2000 Discovery II
Old Feb 27, 2012 | 08:40 PM
Stan the handyman's Avatar
Default 2000 Discovery II
I recently put a used motor in my discovery and it runs very strong... The down side is she stumbles after she warms up and most recently if I let it sit and idle it does ok for about 20 minutes (800rpm nice and smooth) and then it stalls and will not restart until it is cold??? any ideas what it could be?
Old Feb 27, 2012 | 08:46 PM
Classic indicator for crank shaft position sensor. Can confirm by having a spare spark plug and/or a bottle of water. Crank truck, idle until it stalls out. Remove a plug wire, attach to spare plug, lay on manifold, crank and look for sparks - no sparks is the crank position sensor. Or pour a bottle of water on it to cool off quicker, driver side, rear of engine. When swapping sensor make sure you put every nut and spacer back on in exact order. Very sensitive to mis-alignment.
Old Feb 27, 2012 | 08:53 PM
Thanks I will try it out tomorrow
duke051184
Jan 14, 2013 02:23 PM
Disco2Fever
48
Mar 12, 2012 12:39 PM
Airwolf1
Nov 6, 2006 04:27 PM
kennims
Apr 18, 2005 10:35 PM
Tote
Mar 4, 2005 10:34 PM
