2000 Discovery II - Engine shuts off unexpectantly
Old Apr 30, 2016 | 06:00 PM
Sonja Hindman Graham's Avatar
3rd Gear
Default 2000 Discovery II - Engine shuts off unexpectantly
I'm having a problem with the engine, it will stop running randomly, sometimes it will start back immediately, sometimes it takes 15 min. or longer. I've replaced the camshaft sensor twice, that seems to help for about 6 - 9 mo. then it starts again. All lights on the dash will come on for no reason, then I can shut the car off and when it starts again.... they are all off. Any suggestions or has anyone else had similar problems? It has 250K miles on it.
Old Apr 30, 2016 | 06:25 PM
shady milkman's Avatar
Sounds like fuel pump could be going out
Old Apr 30, 2016 | 06:29 PM
3rd Gear
Thanks, do you know if there is any way to check the fuel pumps pressure short of going to a Land Rover dealer?
Old Apr 30, 2016 | 07:11 PM
Any local shop can test it. I had the same thing happen to me on my old D2, it's a pain to get to the fuel pump, but once you get to it, it's pretty simple to put the new pump in. If you find out that's what the issue is I can look up which airtex model fuel pump I replaced it with
Old Apr 30, 2016 | 08:13 PM
Charlie_V's Avatar
You can check the fuel pressure at the Schrader valve on the driver side of the back of the upper intake. You have to kind of feel for it.
Old May 1, 2016 | 06:12 AM
mln01's Avatar
This is the classic symptom of a failing crankshaft position sensor. You say the camshaft sensor was replaced twice -- is that what you meant to say or did you mean to say crankshaft position sensor? These trucks have both.
Old May 1, 2016 | 08:35 AM
Charlie_V's Avatar
I was wondering the same. Cam sensor is on the front cover. Crank sensor is on the bottom driver side of the engine, just above the oil pan at the back. Crank sensor is the likely culprit.
Old May 1, 2016 | 05:13 PM
rankar's Avatar
yup. and very susceptible to failure from moisture if not installed correctly.
NikkiJ
Apr 14, 2018 04:38 PM
Netlock9
Jul 20, 2017 01:52 PM
klh113
Mar 28, 2011 02:08 PM
wiscodread
Oct 19, 2010 06:47 PM
xkelley
Mar 29, 2009 09:03 PM
