2000 Land Rover Discovery
Old Sep 7, 2020 | 04:17 PM
ReconDoc83's Avatar
Originally Posted by Richard Gallant
Hi @Neal Rosenblum and welcome. I am going disagree with @ReconDoc83 on all those things being common issues. Of that entire list I have only done the driveshaft and head gaskets, driveshaft because of inadequate you actually have to grease it. Head gaskets, because I suspect there was a prior replacement and the heads were incorrectly torqued or not trued. . The rear frame is only an issue if you live where there is heavy salt exposure.
everything I mentioned is listed here; and 1/2 a dozen other forums in intimate detail.
the frames were made in India; from cheap steel...another well known fact. The frames were also stored for the entire life cycle of the Disco and Disco 2s on the open lot of the factory where they endured miserable English weather coming off the North Sea...another well documented fact.
do your research; crawl under it; test all the doors; test the windows; look at the hubs....make sure the key remotes work.
BamaDisco
Aug 29, 2018 05:13 PM
kissdisco2000
May 29, 2009 10:56 PM
walkingtall
Dec 9, 2007 03:17 PM
cowgirl1989
Aug 30, 2005 11:54 AM
Tote
Mar 4, 2005 10:34 PM
