2001 DII with a couple of issues
Old May 9, 2013 | 09:51 PM
captain203's Avatar
Default 2001 DII with a couple of issues
Hi all after reading a bit and looking at 6-7 different Discos I bought a 2001 Discovery II. It's pretty clean and surprisingly lacking in rust for a southern Ontario truck. Some minor things need TLC but on the whole not to bad. I do have a couple of codes showing P0102 and P1884. The other issue is the HI/LO range selector. It just moved freely and dose not change anything. I am assuming the linkage is disconnected or broken. Other then that it drives nicely and is tight.
Old May 9, 2013 | 10:37 PM
Welcome.
P0102 is MAF sensor, output is low and below normal threshold. Could be very dirty air cleaner, could be MAF sensor needs to be cleaned. That should only be doe when truck is stone cold and using made for MAF spray.
P1884 is a code that goes with another for the transmission. You would have to have a more advanced reader for the transmission code.
Shop manual set is called the RAVE, free download in links below.
Old May 10, 2013 | 08:42 AM
captain203's Avatar
thanks for the reply and info on the MAF just cleaned it and hope it helps. I read somewhere that the two codes may be related but not sure. Have to get it up on my lift today and have a look at the HI/LO shifter. By the way it has 149 km's on it and I am going to go through a complete service.
Old May 10, 2013 | 08:59 AM
Mojigglins's Avatar
What did you pay for you disco? I live in BC and they seem a bit over priced here especially compared to the states. I have an 02 with 118000 km's in min in and out no issues at all I have had it for two months now. I paid 8500$. We should keep in touch its not easy finding aftermarket parts in canada.
Old May 10, 2013 | 09:37 AM
captain203's Avatar
cleaning the MAF cleared both codes. I am about to replace the wiper switch and a cracked marker light. Found a local source of used parts at a reasonable price. Now just have to look into the HI/LO shifter. Got mine for under 3K
Old May 10, 2013 | 10:16 AM
Mojigglins's Avatar
not a bad deal! there are guys here in bc trying to sell discos with blown head gaskets or blown trannys for 4000$
Old May 10, 2013 | 04:55 PM
captain203's Avatar
well my codes are back and if I clear them they stay gone till I shut it of then there back. Guess I need a MAF
Old May 11, 2013 | 08:45 PM
captain203's Avatar
New MAF install and codes are gone. Now to figure out the issue with HI/LO range shifter.
what the easiest way to get a good look at the linkage? through the console ?
PanamaDisco
May 13, 2014 07:30 PM
bink1109
Oct 25, 2012 05:07 AM
ScreamingLife
Mar 30, 2011 03:08 PM
yukonridin23
Oct 26, 2009 11:14 PM
