2001 Disco 2 starts and then dies
Old Jul 11, 2022 | 07:22 PM
rick.scott's Avatar
Default 2001 Disco 2 starts and then dies
Hey everybody. Need help on my baby. I keep it parked in the driveway which is a slight incline. I start it once a week when I don’t drive it. Went to start it up and the battery seemed dead. Installed new battery and still the same result. No CEL, flashing hazards, no codes. Reset the inertia switch by pressing the button on the firewall. Same result. Never had this issue before. Please help. Thanks in advance!
Old Jul 12, 2022 | 08:46 AM
sqlbullet's Avatar
Does the instrument cluster come on? Lights? Voltage to starter?
Old Jul 12, 2022 | 06:19 PM
The Deputy's Avatar
Check ground cable where it connects to alternator bracket. Remove bolt and clean with wire brush, don't just look at it...corrosion happens between terminal and bracket. If all connections are clean and tight, slide underneath and jump starter terminals.
rick.scott
Jul 9, 2022 10:45 PM
ZMonet
Jan 12, 2017 12:08 AM
southfloridadiscoII
Jul 18, 2011 07:41 AM
imigorski
Mar 17, 2011 01:59 AM
jonsimon
Jan 29, 2007 01:55 PM
