2001 Disco 2 Strange Coolant Leak Drivers side
Old Apr 17, 2015 | 10:09 AM
Vai2kdna77's Avatar
Default 2001 Disco 2 Strange Coolant Leak Drivers side
Hello again everyone! I have yet ANOTHER coolant leak and this time I am stumped. I changed the lower rad hose, thermostat, upper thermostat hose and that seems to be good. NOW- I am seeing a coolant leak on the drivers side underneath the darn truck. I did a pressure test on the system and it is slowly dripping from that drivers side, right by the sway bar. I am not sure what this is or what to even look for. PLEASE HELP!
I am afraid to drive it any real distance because I am worried it will break down. Ready to sell it and get a reliable truck... So sad.... :-(
Old Apr 17, 2015 | 10:20 AM
drowssap's Avatar
did you check the throttle body heater?
did you check the weep whole in the water pump?
keep the pressure tester on it and pumped up, get some safety glasses, a flashlight and an inspection mirror, get dirty
Old Apr 17, 2015 | 01:22 PM
brooksa's Avatar
I had similar leak, used dye and pressure test to track it to the head gasket on front drivers side, parked it and in process of ordering parts to tear it down.
cosmiccharlie
Aug 12, 2020 01:42 PM
freshdew82
Nov 7, 2012 10:07 PM
Enigma753
Oct 13, 2012 12:05 AM
cptshanman
Oct 26, 2008 10:47 PM
