Coolant leaking...drivers side, rear of engine
Old Oct 26, 2008 | 07:10 PM
cptshanman's Avatar
Default Coolant leaking...drivers side, rear of engine
Guys, need your input...
I was looking into a coolant leak I have noticed in my truck. Today had it parked on a slight incline due to hill near my house. Just enough incline for the truck to be nose down...this info might be important as I relate the rest of the story.
Ran the truck to pinpoint leak. What I am seeing is that I am leaking coolant from someplace near the drivers side rear of engine. What am I missing? What is in this area that might leak coolant?
I mentioned the incline to rule out radiator or water pump...
Mechanic last week pressure tested and said radiator...but man...I do not see moisture from radiator area...dry as a bone...
...your thoughts?
Old Oct 26, 2008 | 07:52 PM
Default RE: Coolant leaking...drivers side, rear of engine
With the engine cold feel around the throttle body for coolant, that is a common leak area on DII's.
Look around the head gasket, feel around the back of the engine, look with a flashlight and try and pinpoint the leak.
Sounds like your mechanic is going to throw parts at it until he bleeds you dry or fixes it.
Old Oct 26, 2008 | 10:47 PM
cptshanman's Avatar
Now that I think of it you are probably so on the money...throttle body...bet that's it...I wasn't even thinking about that.
No worries, I wouldn't have let someone change a radiator for me anyways
cosmiccharlie
Aug 12, 2020 01:42 PM
Vai2kdna77
Apr 17, 2015 01:22 PM
freshdew82
Nov 7, 2012 10:07 PM
Enigma753
Oct 13, 2012 12:05 AM
