2001 Disco II Shuts Down
Old Oct 7, 2008 | 08:22 AM
Default RE: 2001 Disco II Shuts Down
Don't use a meter, go to a local auto parts store and have them perform a free load test on both the battery and alternator.
If it is the crank sensor, you will not have a signal to fire the injectors, the cam sensor determines when the ECU should fire the plugs.
Old Oct 7, 2008 | 04:20 PM
jkid's Avatar
Pretty sure the crank sensor has to do with ignition as well. You said that it will turn over, but not start (once hot). Do you have spark at that time as well? The sensor starts working again after it cools down.
Old Oct 8, 2008 | 01:11 AM
tacomatech's Avatar
You check for fuel pressure if crank sensor is suspected. The ignition system relies on the cam sensor signal.
Netlock9
Jul 20, 2017 01:52 PM
pdolan1
Mar 9, 2008 03:39 PM
fahdbangash
Apr 7, 2007 12:39 PM
wslawal
Sep 18, 2006 10:12 PM
ranger
Jun 11, 2006 04:29 PM
