2001 disco overheating ?
Old Mar 4, 2009 | 01:33 PM
van1's Avatar
6th Gear
Default 2001 disco overheating ?
My Disco overheated it got hot and was shut down and towed home. History I had some hose changed and the thermostat. After that I had the gurgle in the dash or heater core. Had an un qualified rover try to bleed it got worse. Thats when it overheated the gurgle is still there. I have taken it to a rover guy reccommended by brit pacific. He checked it and pressured tested engine to check for Head gasket leaks after 3 hours no leaks were found. He also pulled plugs to check for water in cylinders found nothing. There is still a smell of coolant in the engine area. This rover guy was going for replace the engine. It runs fine I now have it at rover dudes in fullerton ca they seem to know what up.
Anyone have input 115,000 mile disco
Old Mar 4, 2009 | 01:36 PM
e-mail me you tele number, I'll call you and walk you thru it.
Old Mar 4, 2009 | 01:53 PM
okdiscoguy's Avatar
sounds like you dodged a bullet. If it is holding pressure and properly bled, you should be ok. Change the oil if it got hot....
Old Mar 4, 2009 | 05:30 PM
If coolant was spilled on the engine it will smell until it is all evaporated or washed off.
ROVERRACER
Jan 9, 2015 08:17 AM
janowski123
Mar 9, 2012 07:34 AM
alaska1557
Aug 27, 2011 09:14 AM
johnkbl
Jan 19, 2010 05:22 AM
bakerww
May 24, 2005 09:35 PM
