2001 Discovery 2 Transmission Cooler Lines
Old Sep 20, 2020 | 10:43 PM
jnieves2019's Avatar
5th Gear
Default 2001 Discovery 2 Transmission Cooler Lines
I need to replace the lower transmission cooler line tried I want a new one and I am having a hard tome finding one HELP
Joseph
Old Sep 23, 2020 | 03:22 PM
disco2k1's Avatar
6th Gear
Trailhead 4x4
7777 Exchange Street #6, Valley View, Ohio 44125
(440) 212-1636
https://www.trailhead4x4.com/services
Old Sep 24, 2020 | 11:08 PM
Discorama's Avatar
What kind of connectors they are using on the radiator?
Old Sep 25, 2020 | 09:28 AM
JUKE179r's Avatar
Thanks for that link @disco2k1 !
I wonder how much they cost.
Old Sep 25, 2020 | 10:09 AM
whowa004's Avatar
over $400 Juke....Lucky8 sells them and has the pricing shown.
Old Sep 25, 2020 | 10:11 AM
whowa004's Avatar
if the cooler connectors are leaking you can replace those push pull crap things with Swagelock fittings. I replaced both trans and oil cooler connectors this summer with great success.
Old Sep 25, 2020 | 02:05 PM
Discorama's Avatar
I used the Swagelok for my custom oil cooler lines. After about 10,000 miles absolutely no leaks. The hose, connectors and adapters I got from Summit Racing. I spent about $200, but this included a thermostat sandwich. I guess the trans cooler replacement can be built for $150.
Old Sep 26, 2025 | 07:59 AM
1Faith's Avatar
7th Gear
Does anyone have the material list for the Swagelok parts? I bought the Trailhead kit several years ago and installed it, several years went by due to life, and I just got back on this LS swap project. Started it up for the first time the other day and both fittings at the cooler leak. Upon inspection it appears that the internal O-rings to the blue fittings of the kit are not large enough diameter. If I can go to Swagelok -> -8AN hose I will just do that. I have not been successful in finding a thicker O-ring for these fittings.
Thanks
I think I found what I need.
EVIL ENERGY 8AN Male to 1/2" Hardline Compression Fitting Adapter Aluminum Black
merebel
Sep 29, 2020 06:32 AM
evoblade
May 11, 2016 01:42 PM
mule2ears
Nov 28, 2015 11:41 AM
Rover Nick
May 1, 2014 08:40 PM
DarylJ
Apr 14, 2011 09:11 PM
