Oil Cooler
Old Aug 10, 2020 | 11:10 AM
merebel's Avatar
Default Oil Cooler
Oil cooler o rings for the transmission side are they same as the ones that fit the engine oil cooler lines?
Reason being I have a set for the engine oil cooler lines and I might need to replace the ones on the transmission on the drivers side cooler?
And if so how hard to replace them ?
Thanks
Old Aug 10, 2020 | 06:26 PM
merebel's Avatar
Removed the line and reconnected and leak resolved it looks like
Old Aug 31, 2020 | 06:41 AM
kgov's Avatar
I have a leak coming from my oil transmission cooler. Did you have to take the radiator out to change the seal at those connections?
Old Aug 31, 2020 | 03:29 PM
merebel's Avatar
no I just cleaned the quick connect areas and release them. You will leak at that point so put a catch pan under it. I had to source new o rings so I bought the kit from harbor freight
Old Sep 6, 2020 | 09:50 AM
kgov's Avatar
I think I need to replace my whole transmission oil cooler. Do I just add some more tranny fluid after? Or should I deal with a drain/flush.
Old Sep 28, 2020 | 12:45 PM
losinov's Avatar
This is what a lot of us did for the LS Swap: https://landroverforums.com/forum/di...zf4hp24-97300/
You should have a local fluids shop that can create a custom line for you using the original connectors that hook up to the trans radiator and the transmission.
Old Sep 29, 2020 | 06:32 AM
kgov's Avatar
After replacing the transmission oil cooler I no longer have a leak coming from the cooler or the connect points but I seem to be still leaking transmission oil from the front and driver side of the vehicle. Any ideas? Going to clean it all up and try to get a better idea of where it’s coming from but it’s hard as it only leaks when driving.
LR03NJ
Nov 18, 2016 08:50 PM
archaeology_student
Aug 22, 2016 11:17 AM
cybercop
Apr 19, 2016 12:52 AM
Beaulim
May 2, 2014 08:03 PM
atancreti
Jul 13, 2011 10:20 PM
