2002 4.0 Tapping/Knock
Old Oct 17, 2022 | 08:47 PM
judderman's Avatar
Originally Posted by Extinct
If that fan comes apart due to wp bearing failure it will take out your trans, ps, and oil cooler hoses. Ask me how I know....
I’ll take that as warning enough to spend the extra time to get my truck and trailer!
Old Oct 19, 2022 | 03:31 AM
harrydarwen's Avatar
Easy to diagnose. Take the belt off (fan cowl and fan off) ... then skinny spinny each by hand and I bet you find the issue. Careful you don't knock a hole in the radiator when pulling the fan -- and careful with the plastic water hose that goes from drivers side radiator over to the coolant expansion tank.
Old Oct 19, 2022 | 02:55 PM
judderman's Avatar
thanks!
its most certainly the water pump, but I’ll change out the idler pulley too and probably the belt (keep the current as a spare) whilst I’m in there messing around
Old Oct 19, 2022 | 06:22 PM
nashvegas's Avatar
Yep I've found when the idler pulleys feel even a little gritty (nice description) it's good to replace them as well.
Old Oct 19, 2022 | 06:52 PM
Extinct's Avatar
THIS! If you can feel a bearing, its bad. If you can't feel it, but you can wiggle it a across the major axis, its bad. And they go down fast from there at engine rpm.
CaptainAaron
Mar 20, 2017 07:09 PM
Childeric
Mar 12, 2014 09:45 PM
Dane!
Dec 12, 2013 09:23 PM
discoboy
Dec 9, 2010 03:57 PM
ryanD2
Dec 14, 2008 08:08 PM
