2002 DII no spark no fuel
Working on a 2002 disco that has no spark or fuel. (yes, the gas tank is full). ECM and TCM have been swapped with known good parts. Replaced crank sensor b/c of logged code. Replaced fuel pump. Has CAN timeout monitoring codes. Truck cranks fine. Ignition coils are fine. Have checked all engine management relays and fuses. I'm tired of chucking parts at this truck and any help or insight would be appreciated!
RE: 2002 DII no spark no fuel
Mike is right, you cannot just "plug-N-play" a ECU on these. The key and the ECU need to match so you will need to take it to the dealer and have them reprogram the key. And yes they need the whole trk.
The key has a computer chip in it and it "talks" to the ECU, with the wrong key the security system disables the fuel pump and ignition. Imagine that, without the right key you cannot steal the trk.
JumPeR04
04-07-2011 09:52 PM
