2002 DII no spark no fuel
Old Feb 22, 2008 | 03:38 PM
britishracinggreen's Avatar
Default 2002 DII no spark no fuel
Working on a 2002 disco that has no spark or fuel. (yes, the gas tank is full). ECM and TCM have been swapped with known good parts. Replaced crank sensor b/c of logged code. Replaced fuel pump. Has CAN timeout monitoring codes. Truck cranks fine. Ignition coils are fine. Have checked all engine management relays and fuses. I'm tired of chucking parts at this truck and any help or insight would be appreciated!
Old Feb 22, 2008 | 03:54 PM
Default RE: 2002 DII no spark no fuel
I believe when replacing an ECU with a used one you also need a matching BCU from the same vehicle or the truck won't start. What was wrong with your original ECU?
Old Feb 22, 2008 | 06:19 PM
Mike is right, you cannot just "plug-N-play" a ECU on these. The key and the ECU need to match so you will need to take it to the dealer and have them reprogram the key. And yes they need the whole trk.
The key has a computer chip in it and it "talks" to the ECU, with the wrong key the security system disables the fuel pump and ignition. Imagine that, without the right key you cannot steal the trk.
Old Feb 24, 2008 | 12:07 PM
^^ECU, TCU, BCU were cleared and reprogrammed with T4 at the dealer, still no spark or fuel. Cleared
Old Feb 24, 2008 | 12:15 PM
^also cleared and reprogrammed adaptations. I've done this a million times working on my own DI and DII so I'm not screwing up contol units by doing so.
Old Mar 5, 2008 | 02:50 PM
When cranking and when key is in position 2, the manual and sport mode lights are flashing in dash. Gear indicator next to odometer (when key is in position 2) flashes in D, 3, 2, and 1 but not in park, reverse or neutral.
Old Mar 28, 2008 | 12:13 PM
Finally! It's alive. It hadtoo much of an air gap between the crank sensor and flywheel.
newtolandie
Aug 12, 2013 12:20 PM
appjcr
Dec 19, 2011 06:23 PM
JumPeR04
Apr 7, 2011 09:52 PM
Dan87GT
Mar 12, 2010 09:00 AM
appjcr
Oct 13, 2008 09:06 AM
