Sponsored by: CARiD
spark plugs and wires directions dII
Old Mar 6, 2009 | 12:10 PM
newtolandie's Avatar
Lightbulb spark plugs and wires directions dII
I have all of the diagrams for this but am not sure how to post them so PM and I will email them to you.
The upper air intake is really not that bad at all to remove (may want to have a gasket handy for refitting though).
I have had the upper air intake off about 4 or 5 times now and here are a few things that worked for me:
-When removing the upper air intake there is a stud off of the passenger side of the intake that needs to come off. (This secures the metal coolant lines to/from the heater matrix). I remember it being a little tricky (I think), so I left it off to make future intake removals easier. The coolant lines seem plenty sturdy with only being bolted to the accessory drive bracket.
-Removing the entire plastic portion of the air intake from the air cleaner to the throttle body (including MAF sensor), just keeps things out of the way.
-Disconnecting the hose from the IAC valve to the upper air intake makes it much easier to get at the bolt under it.
-After disconnecting the return line from the throttle body de-icer, I pulled the plastic line all the way out and tied back. This helps when refitting the upper air intake as it can get in the way of setting it in place. After the intake is refitted the line can just be poked back through and reconnected.
-Removing the four screws holding the coil pack on, helped me to move it around a bit when unplugging/plugging in the wires and is also necessary for removal of the upper air intake as the top ones bolt to it. The two on the top were easy to get to using an 8mm socket with an extension and a swivel (on the socket end). I remember the two on the bottom being a PITA, so they never went back in. The bottom of the coil pack has a clip that clips onto the fuel rail, so I thought that between the top screws and the clip there was plenty of support for the coil pack. The coil pack has to be pushed/tilted back out of the way in order for the intake to be removed.
-After disconnecting all of the other obvious things like connectors for IAC, fuel purge, TPS sensor, brake booster, the other hose for the TB de-icer, and both throttle cables, the intake should be ready to unbolt and remove. Unclipping the wiring harness on the fire wall and letting it rest on top of the clips helps to keep it out of the way during removal.
-Once the intake was removed I put a towel or rag over the lower intake ports to prevent anything from dropping down there (I know it's just common sense).
-It helped for me to climb in from the front and lay with my belly/chest on the alternator/AC pump and look directly down to see the top of the coil pack. At this point, I pulled the wiring harness on the fire wall toward me to get a better look.
-I removed each wire working from the top outer, then top inner, bottom outer and finally bottom inner. The reverse of this should be the order in which they are refitted as it prevents wires from obstructing your view or getting in the way of the one you are working on. I labeled each wire as I took them off the spark plug end, and matched as well as I could with the new ones (not a perfect match with the Mags). I wrapped a piece of tape on the coil end of each new wire and marked with wire number. I wrapped the tape in such a way as to leave a tab that could easily be flipped/turned to make reading the number easier.
-I actually connected each wire at the spark plug end and had the other end of each group bundled near each end of the coil pack, so once I was laying across the engine, I did not have to get back down for anything.
-I put some dielectric grease in each of the plug wires which made plugging them into the coil pack much easier (just don't get any on the outside of the wire, or it may be hard to handle them).
-The RAVE CD has a picture of the wires connected to the coil pack (as looking from the back of the truck). Printing this out and having it up in the engine compartment with you helps alot. Not only does it show the correct numbering, but it also shows the proper routing of the wires, which also helps to keep it orderly.
-Again, working from the plugs in the bottom center of the coil pack, then bottom outer, top inner and finally top outer makes installation much easier.
-Being able to move the coil pack around a little while fitting the wires also made it easier for me.
-It’s a good idea to make sure the coil pack is pushed back out of the way before attempting to re-fit the upper air intake (it burned me a few times).
I have to say that doing the work up front to get the upper air intake out of the way really seemed to make actual replacement of the wires rather painless and orderly.
Old Mar 6, 2009 | 02:39 PM
I helped another site member change out his plug wires on his 03 with SAI. A bit of a pain but it sounded so good when it fired up after wards.
By the way we did not remove the intale, just a couple of pipes.
Old Mar 11, 2009 | 12:05 AM
akajibio's Avatar
Will you please e-mail me some information about plug wire install. man it doesn't look easy!
Old Mar 11, 2009 | 10:22 AM
E-mail me your tele number and I'll walk you thru it.
Old Mar 12, 2009 | 07:14 PM
akajibio's Avatar
Default Thank You!!!
Mike! Thanks for the information and e-mail. I will return the pro-line wires and get some good quality wire as well as the bosch 4 that you recommended. I then take my time and follow your instructions. Hopefully I can get it done in half a day. thanks again and I will let you know how it went.
Old Mar 27, 2009 | 03:54 PM
disco ben's Avatar
I am sure that my diso has the plug wires that it came with 92k miles ago. I was thinking that it might be a good idea to change them as well as the plugs. What are the plugs and wires that make the 4.0l the happiest? Is it really a half day to change the plug wires?
Old Mar 27, 2009 | 04:45 PM
8mm Magnacor wires and Bosch Platinum Plus 4 plugs.
Shout when you get ready and I'll walk you thru what to do.
Old May 25, 2011 | 07:12 PM
jesusfamiily2003disco's Avatar
can you send me the diagrams and instructions to my email? austinjjesus@gmail.com
Old Aug 12, 2013 | 09:28 AM
Vai2kdna77's Avatar
Hey Mike! Can I get some help with the wire installation? I am new to this Land Rover stuff and want to make sure I do it right! My email is kevin.mcwhirk@gmail.com.
Thank you for all that you do!!
Old Aug 12, 2013 | 12:20 PM
dusty1's Avatar
via2, there is a good write up on here
search "Replace Wires Without Removing IM"
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Danny Lee 97 Disco
Jun 25, 2010 05:23 PM
kumbhani123
Jun 12, 2007 04:22 PM
sparky
Defender
Jun 3, 2007 05:10 AM
