2002 Disco II. No fuel
Old Sep 10, 2017 | 07:09 PM
jon4765's Avatar
Default 2002 Disco II. No fuel
I need some help guys. This is the first Land Rover I have ever been around. I just got done doing the head gaskets on it and went to fire it up but am not getting any fuel. I pulled a spark plug and its dry and doesn't smell like gas. I replaced the head gaskets, crank position sensor, and battery all at once and now i am lost. I checked all the fuses and they are good. Any advice would be greatly appreciated. Do I need to crack or pressurize anything to prime the pump again? I tried to listen for the fuel pump but couldn't really hear it but it feels like it turns on when touching the fuel tank. It ran great before i did the head gaskets except the coolant leak.
Old Sep 10, 2017 | 08:14 PM
nickm347's Avatar
On the firewall on the passenger side is a black button, the inertia switch.
You may have knocked it when doing the work. Press it in and see if that does anything.
Also check the ground strap from the driver's side cyl. head to the firewall.
Old Sep 10, 2017 | 09:54 PM
No Doubt's Avatar
You test for fuel by spraying starter fluid past the MAF through the air intake. If that starter fluid gets her to run, then you truly have a no fuel condition.
Old Sep 10, 2017 | 10:06 PM
Alex_M's Avatar
But whatever you do, do NOT spray the starter fluid ON the MAF.
Old Sep 10, 2017 | 10:19 PM
jon4765's Avatar
Well I am happy to report I pulled a bonehead move and pulled the fuel pump fuse while I was doing the work so I could move it in and out while doing the work. Completely forgot I pulled it. Put it back in and it fired right up and runs like a top
Old Sep 10, 2017 | 10:34 PM
lmao glad to hear it
Old Sep 11, 2017 | 02:40 AM
OffroadFrance's Avatar
Dementia eh
Old Sep 11, 2017 | 07:16 AM
Alex_M's Avatar
Haha, happens to the best of us.
Old Sep 11, 2017 | 02:58 PM
The Deputy's Avatar
Well I am happy to report I pulled a bonehead move and pulled the fuel pump FUSE while I was doing the work so I could move it in and out while doing the work. Completely forgot I pulled it. Put it back in and it fired right up and runs like a top
Missed this word this morning, while reading the topic...and thought "how does someone remove the fuel pump and forget that...man, I'm bad...but not that bad...yet...lol.
Glad you remembered your fuse.
Brian.
dillhole
Oct 14, 2013 08:49 AM
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
mark*229
Aug 29, 2010 02:08 PM
britishracinggreen
Mar 28, 2008 12:13 PM
