2002 Discovery II SE7, Rear Door Lock
Old Jul 19, 2006 | 01:28 AM
TwinCities's Avatar
Default 2002 Discovery II SE7, Rear Door Lock
Hey, if anyone has info on this subject it would be greatly apreciated.
I am having a problem ith the lock on the rear door (not the handle like alot of other people, it's the lock itself), if I pull the handle from the inside it will open and the handle works fine when the door is unlocked. It will lock when I push the button on the key but it won't unlock unless I pull the inside handle (from the inside) and the only way to open is the button on the key there isn't anywhere to open it physically with the key. I also checked the child safety switch.
Any Ideas or experiences with this please let me know. Thanks.
Old Jul 19, 2006 | 09:14 AM
Default RE: 2002 Discovery II SE7, Rear Door Lock
Sounds like you have a bad lock actuator inthat door. What happens when you lock and unlock the truck with your remote?
Mike
rcglfr
Jul 2, 2013 02:10 PM
kpl1228
Aug 19, 2012 05:33 PM
DNCIZ
Oct 17, 2010 10:16 PM
philiplarson
Feb 1, 2009 04:42 PM
