2004 Discovery II Rear Door Lock
Old Jan 12, 2009 | 04:42 PM
philiplarson's Avatar
Default 2004 Discovery II Rear Door Lock
I noticed that my back left rear door lock is not working. The tab stays down and will not move up when unlocking the doors. All the other locks are working and the windows are working. I am looking for guidance in troubling shooting.
Thanks
Phil
Old Jan 12, 2009 | 05:12 PM
AK Rover's Avatar
Default RE: 2004 Discovery II Rear Door Lock
Pull the door panel off and clean and lube the actuator. If that doesn't fix the problem then you'll have to replace the actuator.
Old Jan 12, 2009 | 08:59 PM
socalrover's Avatar
hey phil, i just noticed today that i'm having the same problem with the same rear door lock. i also have an 04 disco. if you could let me know what is causing the problem in your case i would reallyappreciate it. thanks, john
Old Feb 1, 2009 | 04:12 PM
Sorry for the delayed responce , but I was able to order a rear door latch off of ebay for $75.00. I installed it today and works great.
Phil
Old Feb 1, 2009 | 04:42 PM
okdiscoguy's Avatar
If you hit the unlock/lock and you hear the actuator working, but the lock just jiggles, you need a new clock spring on the lock. There is a tiny spring on the locking mechanism that offers resistance to the actuator. If it is broken, it will unlock, but instantly fall back down. There is a dude in England that sells them as a complete set. I just replaced 3 of mine and they all work great. Bear to do, but it only cost me about $25
kpl1228
Aug 19, 2012 05:33 PM
DNCIZ
Oct 17, 2010 10:16 PM
rekogniz1
Oct 5, 2009 05:51 PM
TwinCities
Jul 19, 2006 09:14 AM
