Hey all, I've been searching the forum and the whole internet, but I'm trying to find out what nuts and bolts I need to attach the STC53179 2003-2004 Discovery II Nudge Bar. I've tracked down everything else I need (The Nudge Bar, OE Lights, Stone Guards, Covers, and STC50192 Mounting Brackets). The official hardware kit appears to be the same for all D2s, but can't be found: STC50190 Mounting Hardware Kit
Does anyone know the actual sizes of the bolts in this kit? That way, I could just run to the hardware store and call it a day.
Here's a pic I found of the kit contents; I just need the sizes of the 4 longer bolts and 4 shorter bolts.
I plan to mount on my '04. As you can tell by the pic, I like everything to be clean, period correct, and look OE as much as possible.
Thanks!
Chad
The LR part number for the install kit you pictured is RC 190 - someone with a parts book might look up the dimensions for you - if you have a relationship with a LR shop they might confirm the bolt dimensions
