2003 DII Block Heater
Old Nov 21, 2017 | 04:43 PM
Benjamin Runco's Avatar
Default 2003 DII Block Heater
Hey guys, I just had a look around the truck and didn't find the block heater where a stock one would be. My Disco takes an eternity to warm up and I'd like to get a heater in before the snow starts falling.
My question then is, which aftermarket are you guys using and where/how to install it?
Old Nov 21, 2017 | 06:12 PM
Red5's Avatar
I was thinking block heaters this week too. I have one of these in my Amazon cart. Rarely gets into the 20s here in TN, but getting the oil pumping faster is always good.
Amazon Amazon
You can get the type that replace one of the freeze plugs too, no experience with those.
Old Nov 21, 2017 | 07:32 PM
Twix's Avatar
I get heat within 5 mins of starting at minus 20c, shouldn't take much longer
Old Nov 21, 2017 | 07:47 PM
Best4x4's Avatar
Poor man's block heater = electric blanket (in the garage), then if you need it to run warmer in the dead of winter either remove the clutch fan assembly or block off the radiator. This is severe winter storm conditions not just in the 30's lol.
Old Nov 21, 2017 | 09:54 PM
mollusc's Avatar
If your truck is taking a long time to warm up, I would look into replacing the thermostat.
I don't remember reading anything in the RAVE about a stock heater.
Old Nov 21, 2017 | 10:18 PM
Bom2oo2's Avatar
X1,^,,,
Doesn't happen often, but T-stat gets stuck open every now and then, as mentioned shouldn't take more than 5min to reach at least 140*f coolant temp,
humroot
Jul 22, 2019 06:33 PM
Noble Six
Jun 4, 2014 04:51 AM
Blakesrover
Feb 21, 2013 01:43 AM
JBEGIN
Jun 27, 2009 12:38 PM
Used02Driver
Dec 5, 2007 09:35 AM
