2003 Disco II transmission
Please can someone tell me from what years and perhaps other LR models that I can use or interchangeable with a 2003 Disco II and if there will programing issues once I swap it (I have a Autel 619). What trouble can I foresee. My slush box is acting but it is so freaking cold out I have not gone to check and I am contemplating worse case scenario and probably getting ahead of myself, once I check I will post. Just got back to town and my girl been driving the Disco and stated that is "is jumping out of gear while driving"???. Thanks for all the help
03' and 04' are compatible. I know people who have used an earlier model without issue, but the 03/04 is a little beefier to handle the 4.6 motor, so that is the correct part. Always change out the TC to match the trans you put in.
Where are you located? If near CA I have one, if on the other coast I am sure Paul Grant can help you.
If the rover was just a weekend toy, then I would say its OK. But if you do any daily driving or driving in traffic its a lot of work. The clutch is a little heavy and the throw between gears is pretty significant.
I love a manual transmissions, and have 2 alfa romeos with 5 speeds. The are light and zippy and driving them is a blast. Driving the 5 speed D1 I had was tiresome after a while.
texmanmoore
Apr 22, 2015 03:08 PM
abuzar1
Aug 31, 2014 10:40 PM
Greg
Mar 28, 2011 11:09 AM
l3x702
Apr 13, 2009 06:24 AM
