2003 disco II window failure
hi all,
2003 discovery II drivers side front window stopped working the other day(all other windows work). i switched the drivers side switch to the passenger side window to check the switch. it worked, so the switch is fine. i took the drivers side door cover off and tested the motor with a hot lead and ground, works fine up and down. when i press the drivers side window switch i hear a click under the passenger side dash. from reading the post i narrowed it to the bcu. i put my hand on the bcu and pushed the drivers side switch and could feel the click in the bcu. i bought one on ebay and called my local dealer.
they said i could try it and get lucky??
they didn't know if they could reprogram it??
said it could possibly damage other electrical components??
any suggestion would be helpful
thanks
thanks
Pastor Bob (12-11-2018)
Sometimes the power wire to the window motor on the driver's side breaks inside the rubber conduit between the door jamb and the door. Especially on higher mileage Discos where the door has been opened/closed many thousands of times. Check that.
Here's a link to my window dilemma story, and the fix.
https://landroverforums.com/forum/di...-wiring-88550/
