2003 Disco Leaking oil
Old Jan 24, 2009 | 03:51 PM
NiteTrain's Avatar
Default RE: 2003 Disco Leaking oil
prepare yourself for a shock when you get the bill if you have a DII. Changing the VC gasket is not as easy as it sounds since you have to remove the intake manifold to get to the inner bolts.
Old May 5, 2009 | 05:09 PM
kman3786's Avatar
Just have your mechanic just retorque the lower valve cover gasket bolts, this is a common issue and should almost be included in the oil change check list. They just work loose, place some locktight on the threads of the bolts to help hold them cranked down if you like.
Old May 5, 2009 | 05:44 PM
Disco C's Avatar
That is right. Dont replace the seal, just tighten the bolts. Atlantic British sell a throttle body plate thingy that will fix the coolant leak. Cheap and easy.
Old May 5, 2009 | 06:02 PM
Why waste your money having a mechanic torques the 4 bolts, do it your sell till they are snug.
As for any other leaks, go power scrub your engine at a local car wash, then see what new oil shows up.
rally1
Feb 22, 2022 06:22 AM
Paul3221
Nov 25, 2013 12:12 PM
mydisco03
Dec 30, 2009 04:08 PM
Skibum232
Sep 3, 2009 01:03 AM
DeepBlueWater
Sep 27, 2007 07:22 PM
