2003 Disco, Smoke, Syrup Smell and Badly Leaking!
Old Aug 31, 2009 | 12:40 PM
Skibum232's Avatar
Default 2003 Disco, Smoke, Syrup Smell and Badly Leaking!
I was driving home last night, parked and shut off my engine and immediately smelled maple syrup. I was wondering if it was a neighbor but glanced back and started to see smoke/steam coming out from the hood.
Looked underneith and saw a lot of liquid dripping dripping and puddling underneith.
I cannot recall seeing or hearing anything different during my drive home and did not look at any gauges before I shut the car off. Nothing close to this has ever happened before this last night.
Any advice or forecast on how hard this is going to hit my wallet before I call the tow out? I've heard everything from head gasket to radiator.
2003 Disco V8 SE 79k miles
Thanks in advance
Old Aug 31, 2009 | 12:57 PM
98roverguy's Avatar
You'll need to be more specific. What's leaking and where? Sounds like a coolant leak...
Old Aug 31, 2009 | 01:02 PM
Skibum232's Avatar
Looking underneith it was dripping around the engine area but I couldn't see a direct source and it looked like in the middle of the vehicle. I opened the hood and couldn't see anything from the top down.
Hope that helps!
Old Aug 31, 2009 | 01:04 PM
98roverguy's Avatar
Not really lol. Do you know what kind of fluid it was?
Old Aug 31, 2009 | 01:10 PM
Skibum232's Avatar
No I want to say it looked green but low light couldn't really tell.
Old Aug 31, 2009 | 01:22 PM
You are leaking coolant, it shouldn't be green, if it is, you are using the wrong one, should be Dexcool which is pink/orange.
Look at your coolant bottle, it is probably empty.
Do not drive it, sounds like you are not familiar with your engine or very mechanical so I would suggest you find a good Rover mechanic and have it towed to him.
Old Aug 31, 2009 | 01:27 PM
Skibum232's Avatar
I will take a look at it this afternoon. Biked to the office and planned on setting up a tow this afternoon. If either of you know of a good guy in the DTC/Centennial Area I'll tow it on it.
Old Aug 31, 2009 | 01:28 PM
You might also want to make sure you don't have a broken coolant hose, might be an easy fix.
Old Aug 31, 2009 | 01:45 PM
Skibum232's Avatar
Where would I look for that Mike?
My mechanical skills only extend as far as my auto insurance claims adjuster background training so I know the lay of the land so to speak but doing anything with it is beyond me!
Old Aug 31, 2009 | 02:47 PM
hilltoppersx's Avatar
download the RAVE manual. it will answer all your questions like where is this and what type of fluid does this take. http://www.landroverresource.com/
