2003 discovery loud ticking noise need help???
Old 08-05-2009 | 09:50 PM
2003DICSO's Avatar
7th Gear
i got a compression tester today. Whats the best way to test? I mean i know how to screw it in but what kind of reads should i get. Test all 8 cyl. or just a couple. Thnaks
Old 08-05-2009 | 10:17 PM
roverguy7's Avatar
if you have a cyl 4 misfire, and noise from that side of the engine, plug it into 4 and see what you got. yes you should check them all, and they should be around 140-165 or so. if your pissing compression that bad, youll probably only have about 90 on cyl 4. also, to get a good reading, unplug your inertia switch (black tubey switch on the rh rear of the firewall) and then strat it up a few times. let it crank about 3-4 rounds ("pops"... youll hear what i mean) and see what you got
Old 08-07-2009 | 04:05 PM
2003DICSO's Avatar
7th Gear
Ranged anywhere between 140-150 on all cyl. except #4. #4 only has 25 psi. Therefore needs a head rebuilt correct? Please let me know what you are thinking.
Old 08-07-2009 | 04:08 PM
2003DICSO's Avatar
7th Gear
BTW, if anyone is interested in taking on this job, please email me at shotough@hotmail.com. I reside in the DC metro area. Thx!
Old 08-07-2009 | 06:13 PM
roverguy7's Avatar
wow, dont think ive ever seen one that low still running... anyway, you wont know if you need the head resurfaced until its off and you run a straight-edge across it, if it hasnt gotten too hot, the heads probably fine, and just needs a new gasket
lrjon
11-23-2019 06:00 AM
Humdinger
10-18-2016 05:05 PM
p4nth4
12-14-2011 08:52 AM
sloan74
05-12-2011 10:11 PM
rovergirl79
08-04-2005 02:19 PM
Quick Reply: 2003 discovery loud ticking noise need help???
