2003 Discovery steering binds
Old Apr 9, 2011 | 05:22 PM
jafir's Avatar
Default 2003 Discovery steering binds
Does anyone know if the Disco 2 has the same problem that the Disco 1 has with the u-joint in the steering shaft causing the steering to bind up? When I go to turn the wheel very far, it stops. If I give it more force it continues turning. I won't lie, I haven't done too much troubleshooting yet. I checked to make sure there was plenty of power steering fluid and I checked for a beat up steering stabilizer. Both of those looked ok.
Thanks!
Old Apr 9, 2011 | 05:50 PM
jafir's Avatar
Never mind. I should have looked a little harder before posting. It looks like I have a broken engine mount. The mount is pressing against the steering shaft joint.
Old May 11, 2017 | 07:41 AM
JettsRover's Avatar
If its not the U Joint, check your Drag Link and Tie Rod. My Disco 2 would lock-up when trying to recover from a left had turn. Here's what I found:
joshjellel
Feb 16, 2015 10:53 AM
seamonkey1
Tires
May 19, 2011 07:45 PM
jycsalas
Apr 17, 2009 02:21 AM
The Image
Jan 5, 2008 05:43 PM
Evian
Aug 18, 2005 11:34 PM
