2003 front cover remove?
Old Feb 16, 2012 | 07:29 PM
mydisco03's Avatar
Default 2003 front cover remove?
Hi there guy's !! Im trying to remove the front cover so i can install new oil pump gears.... The question is: The whole cover is loose already and also got those 3 nuts out from the oil pan but won't come out? shes already loose but something is holding the cover.... Do i need to remove the oil pan too?
Old Feb 16, 2012 | 08:56 PM
jafir's Avatar
Yes. The oil pump pickup is in the pan.
Old Feb 16, 2012 | 09:08 PM
mydisco03's Avatar
Ok Ok !!! Thanks! I get that out tomorrow!!!! =D
Old Feb 17, 2012 | 05:00 AM
drowssap's Avatar
if you jack up the front of the truck it will give you extra room to drop the pan
Old Mar 9, 2012 | 10:50 PM
mydisco03's Avatar
Thumbs up
Yeah Thanks for your help guys!!! I did the swap with no problems, and it was back in the truck the same day, No leaks and also take my time to clean everything and did some litle paint !!!! The oil pressure went up from 9psi to about 17psi..... this reading is just on idle speed at a normal temp of 190F.... The old pump was fine, no cracks at all.... Dont understand why the oil pressure increase with the new one. but what that heck LOL shes better now. On my 03 the oil pressure is at 22psi on idle. And on another 04 the oil pressure is at almost 30psi on idle. all this is at running temp 0f 190F... Mine runs at 180F.... Looks like every truck is diferent.. The rave said that 7 to 10 psi is good... Theres nothing wrong with 17psi or 22psi or 29psi on idle!!! Also all this trucks are using the same 10-40 syntetic oil with knn filter by castrol. And no additives. Al right guys!!! Thanks for ur help!!
Old Mar 10, 2012 | 09:00 AM
Jared9220's Avatar
Did you use a new o-ring on the pick-up tube? If the old one was bad that may effect the pressure. Also the outer gear can wear but not crack effecting the oil pressure.
Old Mar 10, 2012 | 09:24 AM
Just for fun, what is the new PSI at 2000 - 2500 warmed up?
928paul
Mar 4, 2016 05:26 AM
tmtegt
Mar 20, 2013 07:31 AM
wheelgarage
Oct 1, 2011 03:12 PM
rlrigsby
Feb 12, 2010 08:53 AM
caleb
Jan 6, 2010 11:26 AM
