2003 HSE Disco will not stay running
Old Jan 15, 2019 | 07:38 AM
  #21
Extinct's Avatar
Originally Posted by myD2HSE
Because it will only run for ~5 min, then shut off. It will take a bit of time to get both sets of 02 sensors graphed. Here is Bank A upstream and downstream.
  • FoxWell NT520Pro
  • Live data exported to excel and plotted.
  • the scale is missing a decimal. 4.85 - 4.45V
    • This bank neither 02 seems to be working properly.
These are both working, if they were dead they would be flatline, likely at 0
Old Jan 15, 2019 | 07:48 AM
  #22
Extinct's Avatar
Here is the other O2 bank. It would seem the Down stream O2 is working and the Upstream is not. Maybe I will stick the Upstream O2 from bank A into Bank B and see if this works.
In this view the US A is not working, I would not read too much in to DS B. BTW, DS and US sensors have opposite plugs, so they cannot be easily swapped.
Old Jan 15, 2019 | 09:33 AM
  #23
myD2HSE's Avatar
I was thinking to swap upstream from bank A into upstream from bank B. The near zero volts from DS B is what I was expecting as the more normal value? Based on the two charts any guess on the issue? One bad 02, bad cats, some other issue?
Old Jan 15, 2019 | 09:41 AM
  #24
dgi 07's Avatar
I received my Foxwell NT520Pro scanner on Saturday. For $170 it seems to be a good value, although setting it up and using it was a little frustrating and will take some learning. Today I plugged the scanner in and recorded live data while it idled untill it stalled. ~5 min as seems to be standard. The faults after is shuts off are:
Lambda sensor upstream catalyst bank 1
Lambda sensor upstream catalyst bank 2
Oxy sensor heater upstream cat bank 1
Oxy sensor heater upstream cat bank 2
As I have recently replaced the O2 sensors, I doubt two new O2 sensors are bad in the same manner. I will next try to find a way to record the graph and graph the O2 output from bank 1 US and DS concurrently to see if the sensors respond as expected. I will also need to find my thermal IR gun and record the input and output temp on the Catalic converters.
Why are you so fixated on O2 sensors. O2 sensors won't shut your truck down after 5 minutes. It'll run like **** and smell horrible but wont shut you down
Question, is this a crank no start, or not even a click type event.
That simple question determines how you diagnose. this problem.
Crank no start. Means you are getting not getting fuel, spark.
No start with no response, that's a control unit problem.
Old Jan 15, 2019 | 10:15 AM
  #25
myD2HSE's Avatar
Data... the Foxwell scanner reports a Lambda sensor or O2 sensor fault after it shuts down. Something is occurring to generate the error codes and shut the truck off..
Question, is this a crank no start, or not even a click type event. That simple question determines how you diagnose. this problem.
Crank no start. Means you are getting not getting fuel, spark. No start with no response, that's a control unit problem.
After the truck shuts off and before I clear the codes and reset the ECU, it is a crank no start. Changing nothing but clearing the codes and resetting the ECU and the truck starts. So while indeed it may not be getting spark or fuel when it is not starting, it is not likely to be the fuel pump, fuel filter, injectors, coil pack, plugs or wires given it will start and idle.
Old Jan 15, 2019 | 11:32 AM
  #26
dgi 07's Avatar
Data... the Foxwell scanner reports a Lambda sensor or O2 sensor fault after it shuts down. Something is occurring to generate the error codes and shut the truck off....
okay.... that's consequential. Something is happening way before the truck shut off. Lack or abundance of fuel, air or spark during an ignition cycle will create a misfire. A misfire will sometimes will trip an O2 code. Sometimes. Didn't need to graph them to see it, just look for to see if they are responding. Graphing O2 data isn't going to magically show you what causes your shut down event but let me know how that works out for you.
Clarification goes a long way.
Have you inspected the ECU for corrosion. What about the harness? Both front O2 aren't reading at all. O2 sensors generate their own voltage and if the ECU isn't seeing any, then maybe you should start with either a wiring issue to the ECU or the ECU itself. It also takes an ECU reset (which is what you are doing every time you pull power) for it to run. Which in my experience, bypasses a wiring issue and points right to ECU with an internal fault (software or otherwise).
Old Jan 15, 2019 | 07:36 PM
  #27
Extinct's Avatar
Your bank B chart shows the US sensor as sensor A, is that correct? Does the truck start running rough before it shuts off, or does it just die suddenly? Run a test with the MAF completely disconnected and let us know if it still dies. Record live data on the US O2 sensors, MAF sensor, ECT sensor, and Fuel trims from startup till it dies, preferably hot. Does it still die after 5 mins if you are going down the highway when the five minutes are up? Your sensors look like they are trending rich until the ECU tops out on fuel trims in spite of the sensor reading rich, it could die to rich mixture if that continues. As possible options it could be a bad MAF, at idle we would expect a steady reading, I can compare it with one of mine for the actual reading. It coudl be a bad ECT sensor, indicating the engine is cold when it is actually hot causing the ECU to keep cold fueling when it shoudl be leaning out due to temperature.
Report back what you find and we will see where we go from here.
Old Jan 15, 2019 | 09:47 PM
  #28
myD2HSE's Avatar
As I recently learned something about how to export the data, I am not sure the charts had posted here are valid so I removed them given they are suspect.
I believe I mis labeled the earlier chart. I have posted some from today here. The truck just dies, it is idling fine, then the motor dies. I have not driven it as I have not wanted to get stuck on the road. I can put it up on the lift, put it in gear and "drive it" on the lift to simulate going down the road. I by chance do have a the MAF graph, I will rerun the test tomorrow with the MAF disconnected and collect the additional graphs as well. The O2 graphs are the same data plotted twice. First I am showing the two Bank A sensors then Bank B sensors, followed by both Up stream then both Down stream. The voltage on the Down stream B appears to stay near 4.7V where as Down Stream A is under 1 V.
Old Jan 16, 2019 | 08:03 AM
  #29
Extinct's Avatar
Don't worry too much about the DS sensors, they have no impact on engine tune. The US B is working fine, so it would be good now to swap left and right and see what happens, although I don't think the oxygen sensor are at the root of your dying problem. The MAF should not be varying that much at idle, if at all. I think we may be on to the problem, although it might also be the idle air valve. Running without the MAF will tell us a lot.
It usually is easier for me to troubleshoot because I swap parts from a good running truck to a bad running truck, but you might consider buying presumed good used parts from ebay for testing purposes (IACV, MAF), then selling once you determine yours are good or bad.
Right now my thinking continues to be a bad MAF, I have seen it before.
Old Jan 16, 2019 | 10:19 AM
  #30
myD2HSE's Avatar
I had some formatting issues with the data, hence the graphs were wrong... my apologies, learn something new.
Ok, so take the graphing with a grain of salt as the Foxwell outputs the data in a file format listed serial. I am having to take the data, paste into excel and index the data to graph each diag.I believe I have the data indexed correctly. With the MAF disconnected here are the US O2 and their respective Fuel Trims.
