2003 Questions and DIY Excitement
Old Mar 19, 2007 | 12:19 AM
werldcup's Avatar
Default 2003 Questions and DIY Excitement
Well I have a 2003 Disco and have been doing some DIY 60k service lately and decided to check out my driveshaft for grease fittings. After reading through the forums I decided that I should have my front driveshaft fitted with them to prevent failure; however it turns out my Disco already has fittings on it... I bought it used and I'm not 100% on all the modifications (quite a few it seems)... Is the front driveshaft OEM or has it been modified? (aka do 2003 Disco's have grease fittings on the front driveshaft/u-joints?)
Also, I snapped a bolt on the transmission pan while changing the tranny filter. NOT recommended... what a PITA to fix. Time to buy a torque wrench.
Old Mar 19, 2007 | 11:29 AM
Default RE: 2003 Questions and DIY Excitement
So you are saying that the 2 u-joints in the constant velocity joint both have grease joints? How about the slip shafts on both front and rear drive shafts, have you removed the plugs and installed grease fittings so you can lube them?
Mike
Old Mar 20, 2007 | 02:23 AM
werldcup's Avatar
Unfortunately I haven't greased anything yet as I don't own a grease gun... The jury is still out on what kind I should get.
Hawk99
Aug 1, 2023 10:05 PM
jthomas
Mar 2, 2023 12:26 PM
TRIARII
Oct 16, 2014 09:16 AM
jimmyvietvu
Apr 24, 2013 09:33 PM
EVN137
Jun 15, 2007 06:54 PM
