2003 Ticking but not quite like everyone else's ticking
Old Feb 10, 2014 | 10:32 PM
Dan7's Avatar
Exhaust leak?
Stuck lifter which yes, you need to worry about
Oil pump going out
Slipped sleeve
These are the possibilities I explored diagnosing the tick. Turned out being slipped sleeve in mine.
Old Feb 10, 2014 | 10:33 PM
04duxlr's Avatar
Try the heavier oil and see what happens. If it stops, it was likely the valve train.
Old Feb 11, 2014 | 10:41 AM
Humdinger's Avatar
Fun new twist, it stopped this morning...
Old Feb 11, 2014 | 05:05 PM
earlyrover's Avatar
This is common for the valve train, valve lifters/rocker arms, on these engines, once they get worn ever so slightly. Such ticking is decreased when running somewhat heavier viscosity oils, but when the ticking becomes too obvious, it is trying to tell you that wear of cam shaft, lifters, rocker arms, should be tended to, with new parts replacing the worn ones. You installed new parts in lower end of engine, maybe it is getting close to the time when you should do the same with the upper end of engine. I have seen this sort of ticking sound from all the Rover engines, from the 3.5 litre through to the 4.6 litre; know how common it becomes, once wear takes place.
Old Oct 15, 2016 | 07:37 PM
Charlie_V's Avatar
Originally Posted by Humdinger
Yes, only warm.
The oil thins when it is warm. That tells you it is some wear item.
Old Oct 18, 2016 | 06:51 AM
d.a.r.y.l's Avatar
I hope he has this issue fixed after 2 years and 6 months. Not trying to be a smart ***. D*
Old Oct 18, 2016 | 08:04 AM
Charlie_V's Avatar
Awe damn. Hahahaha. Yeah, let's hope. He may be stranded somewhere though, in need of rescue!
Old Oct 18, 2016 | 08:29 AM
chubbs878's Avatar
how is it that you consistently respond to posts that are buried in the middle of the archive, Charles????
Old Oct 18, 2016 | 08:31 AM
chubbs878's Avatar
surely you weren't search "ticking sound."
you could do your own write-up/testimonial on that subject
VOTE TRUMP FOR PRESIDENT!!
(seriously, though. D2 subforum is lacking a sticky in regard to rebuild guidelines. people are still losing the valve-cover gasket dowels in every part of the top end, using RTV on everything, neglecting the pump gears when replacing the timing chain/gears, etc..)
Old Oct 18, 2016 | 05:05 PM
Charlie_V's Avatar
Hahahaha. I don't know. I look at latest posts. I think my phone is somehow screwing me. I am sure it is! But no, mine is parked. It isn't ticking or making any sounds except maybe a little whimper.
OffroadFrance
Off Topic
May 24, 2015 08:55 PM
OffroadFrance
Off Topic
Jan 17, 2014 04:09 PM
mirepoixmatt
Sep 4, 2013 07:45 AM
Savannah Buzz
Jun 22, 2013 04:01 PM
