@Jason_B Check your vacuum lines particularly where there are bends and it goes into the intake manifold. Any leaks seem to really affect the brake pedal feel in these trucks
If some of the small Secondary Air Injection lines are loose, could that cause a vacuum leak? I am also chasing a bumpy idle that comes and goes, and a check engine light if I let it idle for a really long time. To me this all seems like it could be a vacuum leak. What is the best way to test this? Smoke test?
Finally got these primed, installed and painted. One coat of herculiner today - I will add another coat tomorrow. Etch and prime Setting in place Lining it up Drilling this out burned up my drill! Bolting it up Mounted One coat of herculiner Close up of the finish so far
Thanks Richard. The guy from Dark Crow Designs does some really nice work at a price that is comparable to the ARB stuff. It's all unfinished steel but its pretty easy to finish it up with whatever coating you prefer.
