2004 Disco 2 Engine Rebuild
Old Jan 21, 2020 | 11:49 AM
  #221
Richard Gallant's Avatar
@Jason_B Check your vacuum lines particularly where there are bends and it goes into the intake manifold. Any leaks seem to really affect the brake pedal feel in these trucks
Old Jan 21, 2020 | 11:52 AM
  #222
Jason_B's Avatar
If some of the small Secondary Air Injection lines are loose, could that cause a vacuum leak? I am also chasing a bumpy idle that comes and goes, and a check engine light if I let it idle for a really long time. To me this all seems like it could be a vacuum leak. What is the best way to test this? Smoke test?
Old Jan 21, 2020 | 01:32 PM
  #223
Dave03S's Avatar
Smoke test is how they do it at shops.
Yes those SAI rubber hose ends get loose and leak.
Possible source of vacuum leaks: Three hoses on passenger side of intake plenum, brake master, SAI, PCV. Plenum gasket, Fuel injector O rings...
I had same symptoms, I had both the crank case breather tube nipple loose leak and the fuel injector O ring leaks. Code P1171
Old Jan 21, 2020 | 07:50 PM
  #224
cvhyatt's Avatar
@Jason_B Here's a link to the smoke test I rigged up which easily found a couple of my issues. https://landroverforums.com/forum/di...15/#post709433
Old Jan 24, 2020 | 07:33 PM
  #225
cvhyatt's Avatar
Default 1/24 Update - Dark Crow Rock Slider Unboxing
Finally got my custom built rock sliders from Dark Crow Designs. Looking forward to priming, painting and mounting these this weekend!
Much like the bumpers, this is really stout steel.
Close up of the welds
Old Jan 25, 2020 | 05:41 PM
  #226
cvhyatt's Avatar
Default 1/25 Update - Sliders Installed
Finally got these primed, installed and painted. One coat of herculiner today - I will add another coat tomorrow.
Etch and prime
Setting in place
Lining it up
Drilling this out burned up my drill!
Bolting it up
Mounted
Close up of the finish so far
Old Jan 25, 2020 | 06:22 PM
  #227
Very Nice
Old Jan 26, 2020 | 06:23 AM
  #228
cvhyatt's Avatar
Thanks Richard. The guy from Dark Crow Designs does some really nice work at a price that is comparable to the ARB stuff. It's all unfinished steel but its pretty easy to finish it up with whatever coating you prefer.
Old Jan 28, 2020 | 08:43 AM
  #229
XRAD's Avatar
Looks great!
Old Jan 28, 2020 | 09:27 AM
  #230
RoverSE7's Avatar
Hi, They don't offer powder coating? Do you have a link to this Shop?
