2004 Disco 2 Engine Rebuild
Old Jan 28, 2020 | 11:31 AM
  #231
whowa004's Avatar
I believe they just have a facebook page and last I checked they do not offer powder coating.
  #232
cvhyatt's Avatar
Originally Posted by RoverSE7
Hi, They don't offer powder coating? Do you have a link to this Shop?
No - everything they do is raw steel. You have to coat yourself. Here is there info.
https://www.facebook.com/DarkCrowDesigns/
Old Jan 28, 2020 | 05:27 PM
  #233
cvhyatt's Avatar
Default 1/28 Update
Bled the brakes and tightened down some torque converter bolts that were leaking. Added another coat of herculiner to the sliders. Wish I have used this stuff on the bumpers instead of the duraback, Really goes on evenly with a nice textured finish.
Old Feb 11, 2020 | 07:47 PM
  #234
cvhyatt's Avatar
Default 2/11 Update
Had some slight hesitation with shifting so added some lucas transmission fix to see if that helps. Also started attacking some more of the under carriage rust. Bought a needle gun to help make quick work of it.
2 coats - finished. Will do more this weekend.
Old Feb 18, 2020 | 03:30 AM
  #235
JUKE179r's Avatar
I'm following your story. Thanks for the many pictures!
Old Feb 18, 2020 | 06:50 AM
  #236
mln01's Avatar
How did you add the Lucas Transmission Fix if the transmission fluid was already full? Did you first drain a pint and a half of transmission fluid?
Old Feb 18, 2020 | 02:46 PM
  #237
cvhyatt's Avatar
I opened the transmission fill port when it was semi-hot. About a quart came out. I let it cool, added the lucas, ran through the shifting and topped it off with a bit more ATF until it was dripping out.
Old Feb 19, 2020 | 07:12 PM
  #238
cvhyatt's Avatar
Default 2/19 Update
Had problems with heat coming into the cab. Had the muffler checked out and the said it was fine. I crawled up under there again and found some heat shielding missing. So I ordered this stuff off Amazon and installed it. Also found a place above the transmission that didn’t have any shielding so I partially covered that. We’ll see how this goes tomorrow.
The missing piece
What about this spot over the tranny?
It ain’t pretty but it’s in there!
Old Feb 19, 2020 | 08:07 PM
  #239
cvhyatt's Avatar
Bonus! Looks like it reduced the noise in the cab too. Take a look at my before and after decibels.
Idle before heat shield
Idle after heat shield
Idle to highway speeds after heat shield
Idle to highway speeds after heat shield.
Old Feb 19, 2020 | 09:45 PM
  #240
Sixpack577's Avatar
How do you have that heat sheild material attached?
