2004 Disco 2 Engine Rebuild
Richard Gallant (03-20-2021)
#394
Got the rear diff in. Had problems at first but disconnected rear passenger sway link and that gave me enough room to get it in there. That thing is a beast at 70-75lbs and it’s hard to move around in such a small space. Used a Jack and a strap to make it easier but in the end I had to manhandle it into place. Hopefully I didn’t mess up the rtv too much. Time for a beer!
Adding the weight to the new diff
Success!
Success!
The following 3 users liked this post by cvhyatt:
cvhyatt (03-20-2021)
#397
This picture brings back fond memories of my early days as a mechanic. Whenever we'd hire a new mechanic and get into brakes, long before knock-off drums, and the axle shafts had to be pulled to remove hub/drum assembly...we'd wait...and when new guy had pulled shafts and would step away from the job and wasn't looking...we'd switch axle shafts from one side of the vehicle to the other. We had to stop doing so, because this younger generation had no sense of humor and considered it a hate crime, or crime against humanity (can't remember which...that's what happens to a "boomers"...lol) and wanted their mommy's.
MrHSE7 (03-26-2021)
#398
@The Deputy Too funny! I had to stop and take a second look at the axles to remember their position. I was afraid one of my kids was going to move them around when I wasn’t looking and then the job would have taken me 12 hours instead of 6. I am amazed I was able to put this thing back without screwing something up.
#399
Added the 1” spacers to the rear, filled up the diff and took it for a test drive. No weird noises, leaks or smells. Next weekend I will do the same to the front end.
Spacer installed
Jack on the axle to give me room for the spring with the added spacer.
Fill ‘er up!
Decided to replace the plastic plug with something a bit more durable
Back end a little higher with the spacer. Time to upgrade to 33’s?
Spacer installed
Fill ‘er up!
The following 2 users liked this post by cvhyatt:
Richard Gallant (03-22-2021),
whowa004 (03-22-2021)
