2004 Disco 2 Engine Rebuild
Old 07-27-2021, 07:31 PM
cvhyatt's Avatar
Default 7/27 Uodate
Broke the right front ABS cable at hard rock. Thankfully I was able to splice it back together with low heat solder seal wire connectors. Steering also became sloppy. I thought I had an alignment issue but it turn out the adjustment nut was loose. Easy fix.
Purchased an ARB digital inflator/deflator. This thing is awesome. Easy to air down and up and get an exact setting. Going to add this inline with my smittybilt compressor.
Stripped
Soldered
Wrapped
Looking forward to trying this out at Uwharrie.
The following 2 users liked this post by cvhyatt:
whowa004 (07-27-2021), wjsj69 (07-28-2021)
  #452
Old 08-25-2021, 09:00 PM
cvhyatt's Avatar
Default 8/25 Update
Had some problems with the front diff. It was making loud howling noise while accelerating. The gear oil looked like gray sludge. Talked to Bill at GBR and he told me to send it back and they’d check it out. Hopefully it’s a quick fix.
  #453
Old 09-04-2021, 03:21 PM
cvhyatt's Avatar
Default 9/4 Update
Still waiting on a verdict on the front differential. Should hear back from Bill early next week. In the meantime I decided to do some repairs on the disco. Had a bunch of trail rash from Uwharrie and knocked a couple of panels loose. Simple fixes on the Dark Crow bumpers and sliders. Sand the rusty spots, wipe with acetone, prime and spray on some herculiner.
The Deputy (09-04-2021), wjsj69 (09-05-2021)
  #454
Old 10-02-2021, 08:40 AM
cvhyatt's Avatar
Default 10/2 Update
Finally got the front diff back from GBR. The long and short of it is that the person who assembled it was new and install rear parts in the front and front parts in the rear. It took a lot longer than I had hoped to get the fix shipped back to me but I will be glad to get the disco back on the road after waiting 5 weeks.
Today I am reinstalling the only front differential. I’ll be replacing the rear pinion flange in a week or two. Let’s hope today’s activities are uneventful.
It’s finally here!
  #455
Old 10-02-2021, 10:46 AM
cvhyatt's Avatar
So to just add to the complications, GBR swapped out the 4 bolt flange with the 3 bolt flange. I didn’t noticed it of course until I tried to attach the front driveshaft 🤬
So now I have to remove the current rear diff and replace it with this one. Then I need to take replace the old rear flange with the new 4 bolt flange. What a cluster.
  #456
Old 10-02-2021, 11:28 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
I'm confused...why don't you just put four bolt flange on this diff?
  #457
Old 10-02-2021, 12:44 PM
cvhyatt's Avatar
Because the internals are meant for a rear diff. They assembled it wrong to begin.
  #458
Old 10-02-2021, 12:51 PM
wjsj69's Avatar
Twice screwed on the same part after waiting 5 weeks?!? Wow. NOTED GBR!
  #459
Old 10-02-2021, 01:26 PM
cvhyatt's Avatar
No they did not screw up the second time - I just didn’t understand that they were going to fix the issue by replacing the flange. It’s just me being a noob and not paying attention.
In the end, it’s all good. People make mistakes. GBR is still the best out there. I’m just happy to have a path forward.
Now back to wrenching!
  #460
Old 10-02-2021, 06:17 PM
cvhyatt's Avatar
Got the rear diff in and filled it with redline. Still need to put the armor on it, add the rotors and calipers and wheels but I will get that done tomorrow. Also tomorrow I need to remove the 3 bolt flange and replace it with a four bolt so I can move it to the front. Will need to pick up a slide hammer at autozone tomorrow.
The Deputy (10-02-2021)
Quick Reply: 2004 Disco 2 Engine Rebuild
