2004 Disco 2 Engine Rebuild
#501
#502
11-26 Update
Worked on a few things today. Got the drive shaft installed. Really disappointed with the quality control at GBR. One of the balance weights was knocked off because they just threw it in a box with no packing material. It was pretty trashed by the time it showed up and I had to jb cold weld the weight back on because I don’t have a welder.
In any case, I got it installed, added the diff armor back and cleaned up the front end a bit. Also updated the cost spreadsheet - now pushing $32k.
Build Sheet & Costs
Build Sheet & Costs
#503
Jam nut is loose on drag-link. Yes, it really can't unthread (because other end has lock nut in place and steering stabilizer is bolted to tube)...but...the constant movement/twisting will cause the threads inside tube to wear and eventually allow a dangerous amount of play...and if allowed to continue...could wear the threads to the point the tie-rod will pull out of tube.
#504
#505
11-27 Update
Been chasing the P0441 error off and on for the past couple of years. Hyundai part never seemed to resolve it. I found the Bosch part on autohausz for $35 so I went ahead and got it installed. Hopefully that will take care of that issue.
Rest of the weekend I will be clear coating the front bumper and sliders and removing dirt and rust from the under carriage.
#506
#509
So, it had been running great, you dropped it off and when you picked it up...you got all of these codes in one drive?
Did they do a detail on the rover while there, like wash engine bay or something? That's just weird to get all of those codes...all of a sudden like that.
My first guess...with that many misfire codes, all of a sudden...would be a fuel issue...like a bad tank of gas. That is...if nothing was done, like powerwashing engine...beforehand.
Made the mistake of washing my engine at the car wash, never had a CEL before and always ran great. Nothing crazy, light engine cleaner degreaser, light hose action...no blasting water into spots super crazy. Started it up and had misfire codes like mad, thought...WTF...wash my silverado all the time without the slightest hickup...but...we all know...these LR are what they are. Anyway...drove it until it clear up...and from that day forward...if it spit one raindrop or it was damp out...it misfired. Changed coil packs and wires...but again...my issue was self induced.
#510
Good call deputy. I did wash down the engine bay after the body work because it was covered in dust. So yeah I could have caused this.
I am seeing low voltage on a front O2 sensor so I am going to start there.
Also I had recently cleaned the MAF so I could have messed that up.
Smoke test is a good idea as well and I am thinking that could be after the MAF.
Going to save the coils for last. Too much of a PITA to do first without ruling out the easy stuff.
