2004 disco 2 se SHOULD I BUY??
Old Jan 28, 2015 | 07:30 AM
Dpino456's Avatar
Default 2004 disco 2 se SHOULD I BUY??
Hi Im looking at buying a disco next week it has 112k has had headgasket replaced and drive shaft, needs some work shuttle valve and power steering line what should I look out for? Thanks
Old Jan 28, 2015 | 12:52 PM
G150driver's Avatar
What should you look for???
Ummm, a low price. Despite having HG work and a new/rebuilt prop shaft, there are about a million other things that can and will go wrong. My advice:
1) Read through the forums. You'll notice trends- head gasket and drive shafts are two commonly discussed issues.
2) Take it to a specialist and have a PPI done. They will likely produce a list of repairs around at least $3000. But at least you'll know what you're up against.
Lock actuators, window regulators, sunroof drains, various oil leaks, coolant leaks, slipped cylinder liners, failed oil pumps, overheating, plug wires are a bitch to change... The list goes on.
It's a great vehicle if you like get your hands dirty. Well fed and cared-for, I can't think of another 4X4 I'd prefer. Left to deteriorate they become a can of worms.
Oh, and if you buy it, order an Ultragauge ASAP. The achilles of these power plants is warping heads due to overheat. The OEM temp gauge is a computer controlled piece of garbage.
Cheers,
Gavin
amccullough
May 28, 2013 02:36 PM
newtorovers
Feb 7, 2013 02:52 PM
ljdiscovery
Jan 17, 2009 03:10 PM
roadshadowww
Jan 15, 2009 01:19 PM
bradb
Jul 8, 2007 08:28 AM
