2004 Disco II - Ignitioin Key
Old Jan 13, 2009 | 12:48 PM
captbravo's Avatar
3rd Gear
Default 2004 Disco II - Ignitioin Key
Can I use a copied key from a plan key-blank - no remote control, transponder chip, etc?
Old Jan 13, 2009 | 01:00 PM
salve7's Avatar
Default RE: 2004 Disco II - Ignitioin Key
I can with my 01 disco. I don't know about later years though...
Old Jan 13, 2009 | 01:26 PM
captbravo's Avatar
3rd Gear
Thanks. I'm asking specifically about the 2004.I did it with a previously owned 2001, but I don't know when they went to the "chip keys."
Old Jan 13, 2009 | 01:54 PM
discoboy's Avatar
I have a 2003, I purchased a blank LR key from ebay and had ACE cut the key, no problems, and when they scanned the key, there was no chip.
Old Jan 13, 2009 | 02:19 PM
jdelp's Avatar
I'm gonna try that, it's worth a shot. I bought mine a year old and they only had 1 key with it, so I've only had 1 key for several years. Of all the things I spend money on for this truck, I couldn't justify the stupid $250 programming fee.
Old Jan 13, 2009 | 02:38 PM
captbravo's Avatar
3rd Gear
Getting warmer....thanks, but I need to know about the 2004 model year. I've done it with earlier models and it worked and saved me money, but I don't think it's "worth a shot" unless you know about the chip. I understand you can cause yourself quite an expensive repair bill if the chip is required.
Old Jan 13, 2009 | 02:48 PM
AK Rover's Avatar
Go to ACE hardware or anywhere else they cut keys and they should have a device that tells whether or not your key has a chip.
Old Jan 13, 2009 | 07:15 PM
Rover Curious's Avatar
I have an '03 as well and was able to fab a key out of a different but close blank where I work. We have a scanner as well, and mine does not have a chip. The '04 is the same as the '03 as far as the keys go.
Discolife
Nov 25, 2011 11:38 AM
freelander2002
Oct 27, 2009 05:07 PM
pilsner
Apr 7, 2008 03:24 PM
plastique999
Jan 22, 2008 01:34 AM
Jay
Apr 27, 2005 03:49 PM
