2004 Disco II won’t go into low range
Old Aug 25, 2024 | 12:36 PM
skeetman2's Avatar
Default 2004 Disco II won’t go into low range
I have a disco 2 and it will engage the cdl but not into low range or neutral. I know there’s a solenoid on there to lock it out that’s prone to failure . From my research the solenoid is different on the 03-04 vs previous models. Has anyone encountered this ? What is easiest approach for repair.
Old Aug 25, 2024 | 03:53 PM
Harvlr's Avatar
Is this new? It’s not uncommon on these for the linkage to be corroded and seized if it doesn’t get used often.
Old Aug 25, 2024 | 05:36 PM
Richard Gallant's Avatar
@skeetman2 What year ?
You can try the recommended method get up to about 2-3 mph, pop the Disco in to neutral and let it coast for 100 yds or so then while still moving see if you can get in to low range, it only takes a gentle shove.
Old Aug 25, 2024 | 07:08 PM
skeetman2's Avatar
It’s an 04 . i’ve tried various methods with no lock. Cdl works like a champ though lol
Old Aug 25, 2024 | 07:34 PM
@skeetman2 Well 04 is a bit easier. The cable goes up the right side fro t of the transfer case, you can see it from underneath. Try a whack of oil used for bike or motorcycle cables, and little rental inspection camera helps too, let it sit for a day or so and try again, with luck it will free up.
Old Aug 26, 2024 | 08:06 AM
sqlbullet's Avatar
https://landroverforums.com/forum/di.../#&gid=1&pid=1
This thread has some pictures.
Old Aug 26, 2024 | 12:07 PM
mln01's Avatar
Originally Posted by sqlbullet
I noticed this thread has the exact same title as the linked thread from nearly 10 years ago!
cvhyatt
Jan 31, 2020 02:31 PM
piperpilot
Feb 10, 2016 07:22 AM
samuraisam
Oct 19, 2014 12:13 PM
tombartley
Sep 15, 2014 06:18 AM
hawaiisurfer
May 30, 2011 07:14 PM
